need help on b16 torque spec
i am putting a b16 head on a gsr bottom end and i need the torque spec's so i can torque the cams down and torque the head down. I am using skunk 2 valve spring and retaners with type r cams, also using ARP head studs and oem head gasket. thanks mark
Just got my 20th car and damn its so clean.
ARP studs come with tq specs.
Do a search & you would have found your answer.
You really should be using a helms manual for your cam cap tq specs & head bolt tq sequence.
