brake light on? why?
Old Jul 14, 2007 | 06:20 AM
jojo69's Avatar
Default brake light on? why?
Hey TR!
Just very recently, my brake light comes on... usually when i turn into corners, or when i accelerate real fast... and then it goes away. Sometimes it stays on, sometimes it goes off.
When parked, it lights when it's supposed to i.e. when e-brake is on.
is that a quick fix or do i need to just take out the bulb in the cluster (which i'd rather not do since it aint fixing the cause).
any idea what may cause the light to go on?
thanks
Old Jul 14, 2007 | 06:38 AM
casanova1514's Avatar
civic97
its ur fluid u might have a leak some where fill it up clean the area around the res. and pt cap on snug also look in ur wheels to see if they are greasy looking / extra dirty the flid that leaks mix's with the dirt on the road and makes wheels greasey/dirty real quick
Old Jul 14, 2007 | 07:42 AM
terry.ho's Avatar
I love to choke people.
low fluid.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Jul 14, 2007 | 06:38 PM
jojo69's Avatar
k will chekc fluid level tomorrow during daylight... thx for the input.
Old Jul 14, 2007 | 09:02 PM
nolexforever's Avatar
1. check your brake pads. they might need to be replaced.
2. check and refill your brake fluid.
when your brake pads are worn down, more brake fluid is required in the brake lines therefore causing low fluid to stay in the brake reservoir. that, in turn, activates the fluid sensor and turns on the brake light in the gauge cluster.
Old Jul 15, 2007 | 07:43 AM
rangcrx's Avatar
engine building &best
fluid
i love AUTOZONE
Old Jul 15, 2007 | 08:42 AM
My Honda Is Slow's Avatar
No really,....it is
could be the switch where your e-brake is. could be very sensitive and need adjustment. just a thought
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
