95 gsr..A/C and heat issues..
I have a 95 gsr and the a/c doesn't blow cold when I am stopped and just idling. I have recharged the a/c but it doesn't really help when idling it only starts to blow cool, almost warm when moving. I can feel the compressor turn on so I know that is working. And also my heat doesn't work at all. Just luke warm air.
Any info on things to check.
Thanks for any info.
Chris
Chris
i just found this problem on my civic open the hood makr sure the "heater locker coolent thing"heheheh closes right my air was alwas coming out warm and yet i had the climent controll on ::blue::COLD!! well i open the hood and saw the valve thing was loose and even with the controll all the way cold it still let in small amount of coolent i undid the cable and just moved the valve all the way closed NOW IM FREEZING IN MY CAR!!!
i love AUTOZONE
i love AUTOZONE
make sure to check the bowden cable adjustment for the blend door and the heater control valve(same cable). sometimes that valve may seem to be working properly but it'll will get stuck or break. it's just confusing though considering you dont have heat. how did you put the refrigerant into the system? what are your pressures at? i'd want to look at that with a set of gauges, you might have gotten air into your system....it wont cool for shit when that happens. turn your a/c on and let it run for awhile at idle, then feel the suction line and see if it cools down. it should sweat......i guess give us an update when you can.
~josh
~josh
~josh
~josh
