Crank pulley bolt?
Old Jul 8, 2007 | 08:04 AM
madmanshima's Avatar
Default Crank pulley bolt?
How do I take it off? I need to put it on my new block. Thanks
Old Jul 8, 2007 | 08:15 AM
Alpha's Avatar
You need something (crank pulley holder from Moroso) to hold the crank. A breaker bar. I think it's a 19mm. Someone correct me if I am wrong. May be an 18mm
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jul 8, 2007 | 09:17 AM
I took the Clutch off(Have the motor out of the car) stuck a screw driver through one of the holes to hold in place and used a breaker bar to crack it loose.
Old Jul 8, 2007 | 01:51 PM
custom240sx's Avatar
DC Crew Member #1
19mm...or 3/4" but the 3/4" is somewhat loose which isn't good. Take off the flywheel inspection plate from bottom of tranny, have someone hold a flathead screwdriver in there to jam it and then with a 3 foot breaker bar...break it loose. It WILL take effort to get off even with the 3 foot breaker bar. Threads on it are the same as a normal bolt NOT reverse.
Old Jul 8, 2007 | 01:57 PM
My Honda Is Slow's Avatar
No really,....it is
i have done it a few ways
take it to or if it was still in the car drive it up to a repair shop and give the guy 5 bucks and he will break it loose and tighten it up enough for you to get it off later
use a chain wrench around the pulley and use the ground to hold it. then use a breaker bar. i didnt have an impact last time i did a timing belt and this is the methos i used.
the usa tool truck that comes to my work every week has one on his truck. everytime i step in its right there and i almost buy it cause i know im gonna end up needing it. i have his number and you can call him and meet up with him. alot cheaper than buying it from honda
or if you bring it to my shop tampa in tomorrow, ill be there all day and i can break it loose for you
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jul 8, 2007 | 02:35 PM
TIM TIM TIM's Avatar
could be worse
3/4 impact ftw!
aim:because tim said
Old Jul 8, 2007 | 03:13 PM
No really,....it is
Originally Posted by TIM TIM TIM
3/4 impact ftw!
i used one of those too. i borrowed it from a buddy of mine that works on tractor trailers. it was bad ass, like a jackhammer with 2 huge handles on it. i tapped the trigger once and it was off.
Old Jul 8, 2007 | 04:31 PM
FC_V8's Avatar
Old Jul 8, 2007 | 05:00 PM
sleepinsol's Avatar
starting over
+1 on the 3/4 impact
Old Jul 8, 2007 | 05:12 PM
itsslow's Avatar
I-VTEC, do you?
yeah a 3/4 impact gun should take that baby off in a matter of 1 second. lol. If not, then damn... just get a new pully for the new block.
