no power to radio
infraction king
on
no power to radio
i was moving my amps around my trunk yesterday, didnt unplug any wires at all. i noticed one of the amps, the ground wire was off so i put it back on. i go to turn my radio on and my radio has no power. i checked the fuse under the dash, it was popped so i changed it. still nothing. i checked the fusebox next to the battery for the radio back up fuse, that was popped so i changed it also. still no power to the radio....
any help ........
i hate stereo systems.
any help ........
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
infraction king
on
im haven the same problem in my civic except i changed the dash was working fine finshed bolting it in and now the stereo wont work and my clock wont keep time and i didnt touch the wiring at all lmk if you figure it out
did you check the fuses again after you tried to turn the radio on? If they popped again you have a short somewhere. You'll need to go thru and check to see if any wires are loose or not properly conected. hope you have electrical tape... just my .02.
infraction king
on
no, but thats my next step to see if they popped again
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
Check the fuse in the engine bay, its a 7.5 amp. Its called radio backup, or just backup.
1998 crv daily beater
infraction king
on
aftermarket or stock radio?
if its aftermarkt there is usually an inline filter on the one or both of the power wires running to the head unit.
infraction king
on
its aftermarket. ive checked all the fuses i can find. i need to pull the radio out and check there
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
