b18c1 need help dont know
Old Jun 29, 2007 | 08:03 AM
streetlegends's Avatar
STREETLEGENDS!
Default b18c1 need help dont know
i just had a clutch put in maybe 3 weeks ago & id say a week ago it stopped working the car will run but wen u start the car & try to put it in gear it just wont go? also since the clutch was chaged my car has been sputtering really bad to the point wen u stop it will even shut off??? jus need some help thanx
Old Jun 29, 2007 | 08:04 AM
STREETLEGENDS!
also the motor is in a 93 teg gsr it has a 1.7 tranny
Old Jun 29, 2007 | 09:10 AM
96ek's Avatar
check the ECU ground its on the themo housing.
Old Jun 29, 2007 | 09:29 AM
STREETLEGENDS!
wheres that?
Old Jun 29, 2007 | 09:39 AM
Old Renegade's Avatar
Cool Runnings
thermo housing is where the lower rad hose connects to the block.
for sputtering more than likely check dizzy and components + grounds .
for the clutch seeing the car and tranny i think you are running a cable tranny? if so adjust you cable. too tight won't engage properly and too loose the same thing. if that don't work release bearing may be faulty.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jun 29, 2007 | 10:02 AM
STREETLEGENDS!
thanx ima check that out if not ill get bak to you appreciate it
Old Jun 29, 2007 | 11:09 AM
Cool Runnings
no problem good luck.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Jun 29, 2007 | 12:06 PM
integrex's Avatar
does it go into gear w// the car off??
Old Jun 29, 2007 | 12:24 PM
PAPADEE's Avatar
The throwout bearing probably wasn't lubed correctly or not at all.
Old Jun 29, 2007 | 03:58 PM
STREETLEGENDS!
goes into gear wen cars off just find & to be honest i dont think he lubed it either thanx for the info guys ttt
