Please Help!
I need help with the torque sequence on my head.
1990 CRX Si - D16A6
It shows it in my chilton manual, but it blotchy and i cant see ANY numbers. PLEASE HELP TR, I NEED MY CAR RUNNING!
1990 CRX Si - D16A6
1990 Honda CRX Si - Sold to sprayedtegra
1985 & 1986 Suzuki Quadracer 250R's - Projects
1994 Jeep Cherokee - Daily Driver
Tighten the cylinder head bolts in two steps. On the first step tighten all the bolts, in sequence, to 22 ft. lbs. (30 Nm). On the final step, using the same sequence, tighten the bolts to 47 ft. lbs. (65 Nm).
ahhhh shit, your gonna hate me bro..
i need the rocker assembly torque sequence.. my mistake.
no problem, here ya go
Tighten each bolt two turns at a time in the proper sequence to ensure that the rockers do not bind on the valves. Tighten the camshaft holder bolts for 1984-91 to 16 ft. lbs. (22 Nm). For 1992-95 engines, tighten to the torque specified:
8mm bolts:
D16Z6, D15Z1 engines: 14 ft. lbs. (20 Nm)
D15B7, D15B8 engines: 16 ft. lbs. (22 Nm)
6mm bolts:
All engines: 9 ft. lbs. (12 Nm)
8mm bolts:
6mm bolts:
you can start paying him back by voting for him for mod!
https://www.tamparacing.com/forums/h...plication.html
Nissan, Thanks for helping with the sequence pics.
Rep for you.-Bob
Rep for you.-Bob
