CLutch question?
Old Jun 25, 2007 | 08:11 AM
91Vtec's Avatar
Default CLutch question?
i have 95 coupe. it has a d16z6 and all of a sudden it seems like my clutch doesnt start to engage till i push the peddle like more than half way down. When i start the car i have to like force it in gear to go, its never done this before till now. What do i do about it. How or who can i take it to, to fix it? Please help!
Old Jun 25, 2007 | 08:16 AM
terry.ho's Avatar
I love to choke people.
Check the clutch master cylinder for fluid and or leaks. That would be the first place to start. Also is it making any kind of grinding noises?
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old Jun 25, 2007 | 08:17 AM
ugly86integra's Avatar
Chuck aka Woody
pm'd
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
Old Jun 25, 2007 | 10:20 AM
I concur with terryho, and an adjustment might be in order.-Bob
Old Jun 25, 2007 | 10:22 AM
casanova1514's Avatar
civic97
no adjustment its not cable....read the thread bfore posting a reply
Old Jun 25, 2007 | 11:12 AM
Chuck aka Woody
i talked to him on the phone so it would be easier to find out what it was actually doing. just as most of us suspected, it had a squishy pedal, meaning low fluid. i told him how to check the master and slave cyls. for leaks. he should be good now
Old Jun 27, 2007 | 05:52 AM
While I did read the thread, some cars have adjustments (either factory or not), that can be made and some do not. Your results may vary.
I still concur with terryho.-Bob
Old Jun 27, 2007 | 05:59 AM
Todd's90's Avatar
0711, USMC
my clutch is not cable, and it CAN be adjusted
1990 GS-T
1990 GST
2004 BMW 325i
Old Jun 27, 2007 | 06:54 AM
Chuck aka Woody
in hydro honda's you can adj. the pedal free play with the adjustment on the rod between the pedal and the master cyl., but i think the point that being made was that when your pedal all of the sudden gets squishy, it's not an adjustment issue, 99% of the time it's a leak that need's to be fixed. there's a couple other things that can happen, like the t/o bearing fork breaks, or the arm that goes on the fork shaft cracks. oh, and also the lock nut on the master cyl. shaft can come loose and make your pedal feel all wrong.
