cheapest place to buy a clutch?
Yes...its either a jdm ZC tranny or a Si...they were both an L3...some had an optional LSD...pull the axles and look through the hole and if you can see through it and theres no pin in there you have a rare LSD equipped zc tranny...you most likely have a si one though...check though...im curious now..lol
Im comming
Im comming
here is some info...
what actual tranny is it? look above the oil fill, there is a stamp that will say PL3/####
PL3/A### = small bearing case - DX/HF/STD
PL3/B000 = large bearing - SI/ZC
PL3/3000/6000/9000 = large bearing - SI/ZC
as for clutches, as long as you have a 90-91 flywheel it will use a 90-91 SI clutch. unless the trans is an '88(21 spline input shaft)
Im comming
Im comming
