high compression or low compression?
Old Jun 12, 2007 | 07:06 PM
JDMAddict's Avatar
coolstorybro.
Default high compression or low compression?
i got a acura integra ls b18b1 supercharged. wanting to get a bigger pulley and need to know what kinda pistons to get?
low is a lifestyle.
vimeo
flickr
Old Jun 13, 2007 | 05:24 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
low compression for boosted motors.
you can't go wrong with weisco
-Winston Churchill
Old Jun 13, 2007 | 07:39 AM
Sypher's Avatar
low compression on boosted cars = no low end power
im running 10:2 and 22psi, nice lowend and kick ass top end.
If you want some good pistons check out Endyne and ask about their skirt and dome coatings
Old Jun 13, 2007 | 08:06 AM
slowerthanurgrandma's Avatar
i would stick with low compression i went with 8.8 JE's on my teg and got 25 pounds outta it and i didnt feel like low end was that bad
Old Jun 13, 2007 | 08:17 AM
TIM TIM TIM's Avatar
could be worse
low comp. high will make a little better power but the low will be safer and still alow plenty of boost and power.
aim:because tim said
Old Jun 13, 2007 | 09:46 AM
lilneedle's Avatar
DA SHIFT SUPERVISOR!!!
if you want a beast....tear her down...Go with 9:1 cr...(around stock) and build her...such as..
*head studs.around 100 bux.
*block guard.around 100 bux.
*Shot peened or forged rods. 250 and up.
*Forged pistons.
*main studs.
*good head geasket.
maybe more...that would let yu handle some good power safely...
Holla...rep love...and G/L!!!
Im comming
Old Jun 13, 2007 | 10:31 AM
chi town brat's Avatar
! Ne shab'rud'ni !
which charger do you have on it?
Old Jun 13, 2007 | 10:37 AM
honestly before you build it what kind of boost are you lookin for that'll help figure out what pistons as far as comp. and bore as well as if you need sleeves or just a block guard ive also heard a little about block posting but i wouldnt trust it i had a sleeved gsr with 8.8 compression and standard bore easily handling 25 lbs so...
Old Jun 13, 2007 | 11:36 AM
lilneedle's Avatar
its pinning...its were yu tap into the block from all angles and screw bolts in to where they ae just resting on the sleeves,giving them rigidity..or strength...I hear it is quite affective...I wanted to try it with my build...
Im comming
Old Jun 13, 2007 | 01:11 PM
rangcrx's Avatar
engine building &best
its ok i have done only 2motor build where we tried this...my advise BUY A BLOCKGUARD!!!!!! it is not worth the time plus is limited cause you need up top not mid level and a block guard does that for you.......for me i say buy some gsr pistons for you motor and keep the boost the same LET YOUR MOTOR do more work not the supercharger
i love AUTOZONE
