tranny swap
how much would it cost parts wise to swap a 92 integra auto to a manual tranny? what if i had someone do it for me?
It would cost a lot.
It would be easier if you can find a junked Gen2 5 speed that you could part out and use the parts in your car.
5 speed Tranny
Clutch
flywheel
center counsel for 5 speed
shift linkage
ECU
Wire harness
Master Cylinder
clutch and brake pedals
Misc. bolts, nuts, and brackets.
Probably around $1500+ not including Labor.
5 speed Tranny
Clutch
flywheel
shift linkage
ECU
Wire harness
Master Cylinder
i guess so...
question tho...for something like this you need a WHOLE new harness? and is a new ECU required..my buddy swaped once with a auto ECU in it
no its not required, but u can pick up a ls ecu for ne where from 50-100 bux here on TR, and when ur spending 1500, whats another 50 bux u kno
once you get a tranny..if you are somewhat mechanical smart you can go to like a u pull it lot and pull parts for yourself, you cant hurt, if you mess what you needed up, dont get it...I have a 92 teg and its auto, I have 2 cable trans and I am doing mine soon, need just axles and pedals have everything else...if you need trans lmk
