92 integra ?
I have a 92 integra that is auto, i think i have all i need to do manual swap over, but should i have to change ecu? or would the auto ecu work?
and would i need a manual wiring harness for motor?
PLan to get this car together asap
you shouldnt have to change anything, i have used an auto ECU in a manual car(although it runs better with a manual ecu in a manual car), and at that the wiring is gonna be the same. the only wiring you need for the tranny is the reverse light switch and starter wires....good luck
ok, in the same situation, to change from auto to manual, are the axles compatable, or do i need to get new ones? and mount wise what mounts change between the transmissions
i have...manual trans, cable for clutch, press plate, flywheel, half shaft, I know i need pedals but besides that do you think i need anything else, dont want to take this all apart and then be SOL on a ride for a few days
