compression test
my compresssion on my z6 block/y8 head was 195 across the board, compression on that motor is about 9.5:1.... dunno if that help comparably to the 9:1
is it a fresh rebuild or how many miles on it, if its used?
***!! will pay $$$ for: Black GSR leather front seats and a 92-95 hatch black cargo cover !!***
well the motor is built 9to1 je piston /eagle rods/new all bottom bearing/ except blockguard thats on the block and the head crower spring and retainer and type r cams in the intake and gsr in the exhaust and all bolt on and its running 14psi
I believe the compression numbers are only supposto be around 5-9 off from each other...
another thing, You need to list what block, head, crank, rods, pistons, bore, stroke, has the head been milled, has the block been decked, what size HG? There are wayyyy too many variables to guess what the compression in PSI is going to be for your setup.
