Clutch /Tranny Problem!!!!!
Old May 26, 2007 | 09:34 PM
isaacvela06's Avatar
Cronic Masterbater
Default Clutch /Tranny Problem!!!!!
My maint. req. light came on and soon after my clutch started actin wierd. It sometimes sticks down when i go to shift. Thinkin it might be the clutch slave cylinder or somethin. Pm me if u think u have the prognosis. Thanks
DC2 WHORE
Old May 27, 2007 | 09:59 AM
Cronic Masterbater
DC2 WHORE
Old May 27, 2007 | 11:18 AM
Cronic Masterbater
DC2 WHORE
Old May 27, 2007 | 11:19 AM
Old Renegade's Avatar
Cool Runnings
if you need i got a brand new never opened Type R pressure plate. 813-679-9467 also got a pilot bearing new also.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old May 27, 2007 | 03:09 PM
Cronic Masterbater
Cool but do u think thats the problem thats what im tryn to find out. If it is tho know where i can find the part. Thanks
DC2 WHORE
Old May 27, 2007 | 05:35 PM
Cronic Masterbater
Help Me Plz
DC2 WHORE
Old May 28, 2007 | 07:36 PM
Cronic Masterbater
DC2 WHORE
Old May 31, 2007 | 03:11 PM
Vcruz's Avatar
I believe its ur slave cylinder 2 u should start there anyways its cheaper than a clutch....
Old May 31, 2007 | 09:26 PM
1BADP71's Avatar
E & I Certified
hows the fluid level ?
it could be your master cylinder leaking fluid past the seals . you would show signs of it leaking on the inside of the car . check the carpet on the firewall where the clutch pedal master cylinder is . if thats it , change that and the slave at the same time . putting a new master on a weak old slave will cause it to malfunction sooner .
Old Jun 1, 2007 | 04:11 AM
Sypher's Avatar
or if tranny was taken out recently and the line wasn't hooked up tight it will cause air in the line. look along the whole line for visible leaks
