how to check codes on obd1 ecu?
Old May 8, 2007 | 10:23 AM
JoKiE crx4294's Avatar
popeye built!
Default how to check codes on obd1 ecu?
I Just Recently Converted To Obd1 And Have My Check Engine Light On. Can Someone Tell Me How To Check My Ecu To Find Out What Code Im Throwing. Thanx
Can't spell strength without tren
AAS...It's whats for dinner
Old May 8, 2007 | 10:28 AM
Sypher's Avatar
if the car was obd0 the conversion harness should have a wire that you just ground that will flash the cel.
if it was obd2 you test it the same way as a obd2. unsure your year so wont go into details
Old May 8, 2007 | 01:50 PM
popeye built!
It Was Obd0 Before
Old May 8, 2007 | 02:07 PM
Sypher's Avatar
then there should be a wire labled or the person that supplied the harness should be able to tell you what wire (if any) on that harness you can ground and check your codes.
otherwise you will have to find the obd1 pinout for the cel wire to ground that
