Small but Big problem?
Old Apr 29, 2007 | 07:00 AM
doefat07's Avatar
Default Small but Big problem?
Ok so another one of my problems is my widshield wiper stick is broken. its there but its loose and dosent turn on my wipers making it probly an easy fix but a BIG problem since we live in FL and i cant drive in the rain untill its fixed. how do i go by fixing i havent had time to take the molding around it off yet.
Old Apr 29, 2007 | 08:26 AM
JDMBlackGSR's Avatar
Gators Bitches!
I had the same problem with mine, the little plastic ball on mine cracked......this is what I did, you have to take the whole motor out, and at Lowe's they have little rubber seals, there is one that fits perfectly, place that on the arm and then around the ball joint. Then get a small drill bit and drill through the ball and put a cotter pin through it so that it will not fall off, and your good. Worked on mine, never had to replace or anything.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Apr 29, 2007 | 10:06 AM
doefat07's Avatar
dam sounds like replacing it is easier. lol i gotta check it out asap. but it dosent fall out but it dosent feel like its attached to anything.
Old Apr 29, 2007 | 01:35 PM
Gators Bitches!
yea, there is an arm that moves them back and forth, that fell off of my motor....its actually easy and a lot cheaper
2003 Accord EX-L V6
Interior
Exterior
Suspension
Engine/Performance
Old Apr 29, 2007 | 01:38 PM
Sneakin Deacon's Avatar
PSSHHH x2
are you referring to the wiper blade arms, or the on/off switch on the steering column.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
