B16 Issue With Vtec
Old Apr 22, 2007 | 11:18 AM
LATINO HONDA's Avatar
BALLER
Default B16 Issue With Vtec
I Connected The 4 Wires And I Dont Feel Vtec.the Engine Light Was On Before I Wire It Up And Now It Is Off But No Vtec And No Codes. The Code Was 21 In A Ef Obd 0. If You Have Any Suggestion Help Me Out
Old Apr 22, 2007 | 11:20 AM
dougy_fresh's Avatar
what was ur highest rpm..?
  • - 1997 Bagged Layed Out Nissan HardBody..
    also check my post for stuff for sale...
Old Apr 22, 2007 | 11:42 AM
BALLER
7500 0r 7800
Old Apr 22, 2007 | 03:03 PM
SilvCivOn17s's Avatar
cause the whistle goes...
was the car warmed up? did you hook the 4 wires up to the ecu right? did you hook up the knock sensor? what ecu are you using?
R.I.P. Brian Nichols 02/07/1989-11/23/2008
Old Apr 22, 2007 | 06:58 PM
Brownsound's Avatar
Dude.. thats awesome.
Requirements for vtec (to my knowledge)
above required rpm (obviously)
engine temp above 150 degrees
going faster than 13mph
If vtec was not working then, check all the connections you just did like 3 times, then go ask somebody who knows more than I do.
Old Apr 22, 2007 | 07:33 PM
EGKID's Avatar
also check your oil, and vtec solinoid make sure the screen is not clogged
Ricky
Old Apr 22, 2007 | 10:49 PM
nolexforever's Avatar
reset the ecu after connecting the wires?
Old Apr 23, 2007 | 03:12 AM
Steve C.'s Avatar
hoollaa
did you wire the knock sensor? try wiring the knock sensor!
