Spring Recomendations?
HOWEVER, If you are planning on lowering your car 2" or less and you use a spring like Eibach, Neuspeed Sport, H&R Sport or either Tein S-tech, H-tech, You should be fine for quite a while.
These Springs are generally promoted/made for just this situation..........unless you are close or past an OEM shock's life expectancy of 65K miles
If you lower a car on stock shocks/struts, You have a safe resting area of about 1.75"-2" in the shock, This is called the "Sweet Zone" (no, I didn't make that up).
The definition of Sweet Zone: The inside top area of the shock where the piston sits when not being compressed or in action.
This area is stronger then rest of the shocks inner wall and is made for the piston to sit in when not being compressed.
+1 ... tein s-techs only drop your car about 1.7 -1.9
I © my Honda
i need
96-98 rear bumper (black)
96-98 fenders & hood (black)
rear filler panels (under tailights)
glove compartment lid/cover ( dark grey)
driver side ac vent(upper dash one)
TR "F#UCK Thieves" crew Member #10
I © my Honda
i need
skunk2's with koni yellows
._________________________
I've had good luck installing Skunk2's for people,
but 1.5" seems to be a good street lowering.
Sitting them too low destroys shocks when
you go over a bump and the shock bottoms out.
And be aware that with some spring MFG's, to
get the advertised drop, you have to also buy their
shocks.-Bob
shocks.-Bob
awsome thnx guys +1....
I will probably forget about the slam and just go with an ebach set up , from what i hear is a very good spring and only frops 1.75 which is still better look then stock lol
thnx again guys
thnx again guys
01 Civic - Daily
01 525i - Sold
98 Accord - Sold
01 Civic - Daily
01 525i - Sold
98 Accord - Sold
JUNK2 sucks i had a set of springs and they gave me nothing but problems.
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
like i said before s-techs! best for oem shocks
I © my Honda
i need
I © my Honda
i need
I had Tien S.Techs with stock shocks on my EG hatch, they lowered it nicely and were not bouncy at all. I was still able to clear parking curbs and what not, but then again I didn't have a front lip. They do throw your camber off a good amount though.
I think they were great for the price.
Ricky
Ricky
