tranny whoas
Old Apr 11, 2007 | 05:49 PM
jdm_Trex's Avatar
Default tranny whoas
ok so i bought a gsr swap recently. it went in my crx so i traded my tranny for a cable j1.... not knowing if either of the transmissions where "good".
so heres my problem: when driving it gets stuck in 2nd... after i push the shit out of it pops out to neutral. then 5th is way the fuck over to the right. i know the linkage is good. the only thing i can think it could be is the tranny........
WTF could it be please help!?!?!?
Old Apr 11, 2007 | 06:25 PM
sleepinsol's Avatar
starting over
ya sounds like somethin inside the tranny fo sho. um....synchro, blocking ring, could b anything really. ur describin 2 different problems here so it could b more than one major thing wrong. check ur clutch too. is it hard to get into all gears? does the car shutter/chatter when u take off? could b a bad clutch if this is the case. trannys and clutches are hard to diagnose tho.....
Old Apr 12, 2007 | 09:29 AM
jdm_Trex's Avatar
no its not the clutch.....
2nd gear is the only gear it gets stuck in. it goes in fine and there are no grinds. if it where syncros wouldnt it grind......
Old Apr 12, 2007 | 09:39 AM
el b18's Avatar
$$ = boost :( = NA
slave cylinder?? check for leaks behind the carpet ! my problem was so strupid i almost diesd
Old Apr 12, 2007 | 10:21 AM
Gixxer's Avatar
Hide your daughters
I think you mean "woes" not whoas" lol.
Old Apr 12, 2007 | 10:39 AM
itsslow's Avatar
I-VTEC, do you?
i believe 5th gear is supposed to be all the way to the right? However, i could be wrong though.
Old Apr 12, 2007 | 11:36 AM
sleepinsol's Avatar
starting over
um.....if the syncros are VERY bad theyll grind, otherwise it just makes shifting a pain in the ass. check the hydrolics too....
