CV Joint
exactly out of balance shafts will have bad vabrations. had that happen to me also, only realized after the tranny was out for inspection
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
The car might be pulling to one side because of a misalignment.
A lot of times a person doesn't need an alignment unless the ball
joints go bad or get replaced............or if something else has moved.
When I do ball joint tests, I actually pop them loose, and show the person the difference between a good joint and a bad joint. Some places do the shake 'em and sell 'em test, which I believe to be inadequate.
When I replace balljoints, I also can check the alignment using the portable alignment set like they use in the garages at the Indy 500.
If you want a quick check of the alignment, get back with me.-Bob
This may sound like a dumb question.......When you replaced the axle,
how much transmission oil did you have to add to bring it up to full?
NEED BOAT PARTS ? TR MEMBERS GET 15% OFF YAMAHA OUTBOARD PARTS
I AM THE PARTS MANAGER OF CENTRAL MARINE. CALL 727-347-9799 AND ASK FOR KARL.
