type-r head???
Old Apr 3, 2007 | 04:35 PM
importeclipsegst's Avatar
Default type-r head???
if its recomended to upgraded your valve springs and retainers on a b16 head when changing to type-r cams if i have a type-r head and wanted to change to skunk2 stage 2 cams do i have ti upgrade the springs and retainers on the type-r head ?
thanxs
Old Apr 3, 2007 | 04:39 PM
EGKID's Avatar
It would recommend it, I know with the stage 1's you dont have to but I'm not sure about the stage 2's
Ricky
Old Apr 3, 2007 | 04:54 PM
JH26's Avatar
ΜΟΛΩΝ ΛΑΒΕ
skunk 2 reccomends u upgrade the valvetrain with the stage 2 cams
are the stage 1's any better than the stock type-r's?
Old Apr 3, 2007 | 05:28 PM
Jason2801's Avatar
It is what it is
they are but not by much, I would rather save and get the stage 2's....or stick with the ITR cams rather than spending money on stage 1 cams, just my opinion....g/l
Old Apr 3, 2007 | 06:30 PM
nolexforever's Avatar
to utilize the full potential of the stage 2 cams, you'll want to upgrade the valvetrain and adjust the redline on the ECU. adjustable cam gears and a dyno-tune will help too.
Old Apr 3, 2007 | 08:18 PM
Eluzzionz's Avatar
specifyin ur set up might help us to determine what is in ur best interest...if u have a type r head..getting cams to me isnt worth it..u already have a bad ass head..but what block are u using..sticking to all motor?..the most beneficial thing to me would be puttin in higher comp pistons..i think it would yield higher hp gains and excluding installation would cost the same...unless you can get some oem pistons that are higher comp then whatever you have..
Old Apr 4, 2007 | 08:29 AM
integra's Avatar
90% grind 10% sleep
stage 1s are fine buy those and then a nitrous kit with the extra money
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
