throotle body and manifolds
Old Mar 31, 2007 | 06:48 PM
ray123's Avatar
Default throotle body and manifolds
how much will a throttle body do 2 myh car cause ive heard that the h23 throttle body fit on the f22 engines and so does the whole manifold as well but im wondering should i change the throttle body only or should i change the wholoe mani and how much power will i get if i only put the throttle and how much will i get if i get the manifold completly..sorry if i made it difficult
chilling
Old Mar 31, 2007 | 10:53 PM
sxecrow's Avatar
EG2 CRX
There is a guy in orlando that can bore out your stock throttle to whatever size you want. This way it fits like it did before, but gives that extra flow. If interested, check out Maxbore.com throttle body boring service
Old Apr 1, 2007 | 07:23 PM
ray123's Avatar
how much power will somehting like that add
chilling
Old Apr 1, 2007 | 08:07 PM
sxecrow's Avatar
EG2 CRX
uhh h..... exactly 7.2 hp and 3.4 ft lbs of torque?
add red stickers and you might get more.
I know that sounds dumb but the point I'm making is that you won't know until you dyno before and dyno after. Depending on other modifications to the motor, it might work better.
Old Apr 2, 2007 | 06:04 AM
Tightcivicexboii's Avatar
Honda Gear Head
Yeah 7.4hp and 3.4lb ft of torque sounds bout right. The throttle body just basically gives you a chance within an orifice to gain more horses and torque with more air entering. Boring the throttle body to about 70mm use to be greatly wanted in the 70's in motors that were carburated.
No project currently. Getting my ASE Certifications Completed.
Old Apr 3, 2007 | 07:59 PM
BoostFed95's Avatar
If anything, change the IM and leave the TB stock.
There would be no point at all to change/bore the stock TB and keep the same IM. That would be like equivalent to running a 3" DP w/ a 2.5" exhaust...which is called bottle-knecking, and a big no no
