a/f ration & egt readings on a stock d16z6
what he was saying is that your EGT reading will varry due to location so its hard to give that info without more info.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
Idle sounds about right if you are around 800 rpms. EGT depends on several factors, including where you have the thermcouple/sensor attached.
Is this car tuned or a stock ecu? In other words, what is it you are trying to accomplish here?
on
is two inches from the exhaust port . I just having everything hook up and ready and in working order for when I finished and drop my swap Thanks for the info..........omar
