Timing belt?
i just put a new timing belt on my ls. but for some reason when the belt moves it gets tight, lose, tight, lose when the crank turns right in the front where you can see it. is it supposed to do that??? i would think not but let me know b/c i need to get my car running... thanks
i would recheck the tensioner to start with
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
If it is going loose tight loose tight then it sounds like something is bent or out of round. I dont see how the tensioner could make it go tight loose etc etc. Make sure the tensioner is locked in place & rotate & see at what point it changes from loose to tight.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
did you properly rotate the assembly. your suppose to tighten your tensioner, turn the motor over by hand from the crank 3 times. then check the tensioner once again/
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
it will do that a LITTLE bit, but the tentioner is what fixes that.. pm alpha and ask him his suggestion, they got mine right whhen i couldnt get it
+1
i guess it all depends on what he's calling lose and tight, and also the direction that he's rotating the crank.
but yeah, if you're rotating the crank counter clock wize smoothly, and the belt gets tight in a certain position and then pretty loose when turned a lil more, and then back really tight again, it's got to be something bent, or something stuck in the teeth on one of the spockets.
i helped a guy that was having that same problem a while back, and he had a few peices of old T belt stuck in the teeth of the crank sprocket.
his motor sheared the teeth off of his belt and i guess it was pretty hot when it did it so some of the belt teeth kinda glued theirself in the sprocket teeth.
now on the other hand, if there is just a lil variance in the tight and loose, it could just need to be tightend a lil more. epecially if you're turning the crank backwards or kinda sloppy like stop start stop start.
it all depend's on just how loose and tight we're talkin about here!
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
