i need help
i got my timing belt put on and forgot to get my pistons TDC. So when i got them TDC and my cam gears aligned right it still will not start. i have tried a whole lot of diffrent things. Also when i try to crank the motor over smoke starts to come out of the throtle body and i know thats not good so i need some help b/c i do not know what to do.
Thanks
Thanks
ya i accidentaly did turn the motor over out of timing. yes i took the spark plug wires out. i have had my friend tell me that the front cam gear arrow should be straight up and the back cam gear quarter to the right but i did some research and it says they should both cam gear arrows should be straight up???
you are saying you have the cam gears right, but it's not clear what your notion of right is - yours, your buddy's, etc.
#1 piston at top dead center and both cam gear facing up/up and the two facing center alignment marks on the cam gears should be aligned facing each other? Yes or No. If no, you have to fix it.
