my SRS light stays on
Old Mar 16, 2007 | 08:59 AM
CivicRacingFL's Avatar
Dorado, PR
Default my SRS light stays on
any advice on that
Old Mar 16, 2007 | 09:02 AM
Thatguysstuff's Avatar
Hey its that guy!!
have you taken off your steering wheel????? The SRS is your saftey restraint system.... Something to do with your airbags, Seatbelts, there is a thing on the back of your steering wheel that i think is your steering wheel position sensor.... thats why mine was on...
Check your airbags and steering wheel...
Old Mar 16, 2007 | 09:04 AM
Dorado, PR
no i havent taken nothing off that system
Old Mar 16, 2007 | 09:13 AM
DD.'s Avatar
DD.
Administrator
ok...
So take off the steering wheel and see if the sensor needs replacing.
Also, disconnect your batterie when you do it!! You dont want your air bag going off while your doing this. Believe me.
Old Mar 16, 2007 | 09:21 AM
Dorado, PR
k ill try that
Old Mar 16, 2007 | 06:12 PM
TSX24L's Avatar
when you first start the car does the srs light go off then come back on?
have you wried anything under the dash to a related srs fuse or circut? Increased amount of resistence in srs circut will set a light with no srs dtc.
Also a low battery can set a srs light. Also if any srs components that have deployed without replacing the srs unit will set a srs light with no dtc.
Old Mar 16, 2007 | 06:48 PM
FC_V8's Avatar
Most likely your SRS plug is disconnected.. i say if you dont care of having an airbag, then just take out your cluster and pull out the bulb that goes in for that.. thats what i did..
Old Mar 16, 2007 | 07:02 PM
MAYMAY's Avatar
i changed my steering wheel and srs light came on..so i torn the dash cluster apart trying to find that bulb ..but couldnt find it..so i had to tear the whole custer apart..and broke that bulb...
Old Mar 17, 2007 | 06:16 PM
Dorado, PR
ill try it
Old Mar 18, 2007 | 05:57 AM
MAYMAY's Avatar
ill try it
it is hidden under the face of the cluster..
u have to carefully lift the face of the speed indicator face
if i remember right.it is located on the lower right cornor and
it is hard to take the bulb out..so i just use a plier and break it
