Fixing Your Oil Leak
Old Mar 15, 2007 | 05:48 PM
Default Fixing Your Oil Leak
Someone asks:hey man i here you can pretty much do anything?? i just swapped my motor cuz i had and oil leak from the engine before and now i still have an oil and i dont wanna spin a rod like i did in my old motor you think you can help me out with this oil leak?
Senor Honda says:
You might be able to fix the oil leak yourself.
Get an aluminum valve cover, if you don't have one-about $10 recycled.
Not knowing your specific motor, engine gunk (store brand) costs only a couple dollars. When you come back in with a warm motor, Front end on jack stands, plastic bags tightly wrapped/tied around the distributor, gunk/spray it down over, under, all around, let it soak in, and wash it off throughly. Even underneath. That way you can see where the oil leak's coming from. Pressure washing works better than a garden hose.
Replace the hard/dried out valve cover gasket,
with a soft new one with high temp red silicone
gasket-goo.................replace the o-ring in the distributor shaft groove, carefully marking the dizzy before you remove it,
Drive the car a day, and using jackstands, slide under, and see with a light,
if oil is seeping from the oil pan gasket.
This should get you started..........post up the results on this thread and help us all get smarter.-Bob
Old Mar 15, 2007 | 06:10 PM
TSX24L's Avatar
why not just clean it off and use a powder type leak detector? Fast, simple and effective in finding leaks. I would never use "gasket goo" either to seal a leak. It looks like shit.
Old Mar 15, 2007 | 06:13 PM
sprjit22's Avatar
Rick James bitch
who asked that? lol
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
