B18A1 Torque specs?
Old Mar 14, 2007 | 12:58 PM
SmokinS13SR20's Avatar
That ginger...
Default B18A1 Torque specs?
Anyone know the torque specs for the arp head studs for a b18a1, trying to put this motor together for a buddy and I cant seem to find the specs...
Old Mar 14, 2007 | 05:35 PM
70ina30's Avatar
Broke Dem Ankles
just did my arp for my lsvtec...
spec sheet that came with the bolts said 85 ft lbs..
thats what i did
Old Mar 14, 2007 | 06:44 PM
FC_V8's Avatar
my buddys gsr we did first 25lbs.. then 80lbs.. and it runs great..(with arp lube)
Old Mar 14, 2007 | 07:05 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
i usually dont do anything over 75lbs for my lsv's...many built
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Mar 15, 2007 | 05:36 PM
civicized's Avatar
ARP head studs for b series vtec is 65 lbs or 70 lbs, depending on which line of their spec sheet you read. One says 70, then second says due to aluminum exansion, 65 lbs is recommended.
In both cases, that is with ARP lube. 85 is I believe what they recommend for engine oil as a lube. I solve the 65/70 torque question by going 68 lbs. with arp lube. Golden Eagle studs use OEM torque specs
Old Mar 15, 2007 | 07:40 PM
That ginger...
Called gearhead and they said 63ft/lbs
Thanks for the input guys
