Yet another car wont start thread
Old Mar 13, 2007 | 11:05 PM
Talon95's Avatar
Fakes the funk
Default Yet another car wont start thread
Alrighty i did a search but didnt help. Ok saturday night i was leaving a friends house and had no problems, stopped at a gas station and when i got out the car would not start. when i turned the key it just did nothing, no clicking no noise at all.tryed smacking the starter but didnt help. push started the car and that worked. everyone told me it was the starter so i put a new one on today and still have the same problem. thought it was clutch switch so i bypassed the switch and still nothing, checked all the fuses and was still good,tried jump starting it and did nothing. i called my friend who is good with honda's and he was stumped. anything else that i could try or check?! i need this fixed!! oh its a 91 integra with a ls if that helps at all
Originally Posted by Alpha
Boost > all motor. Usually the only reasons people say different is because they cant afford boost/power, have never owned a boosted car, have never ridden in or driven a properly boosted car, etc.
Old Mar 13, 2007 | 11:18 PM
B18C14's Avatar
Spoolinfool
If you have the power running to the starter, tried to jump it and nothing happened, givin the starter is new as you said, you have no ground. Run a set of jumper cables from the battery to the starter and hook it up to the power lug. Then try to jump it over. If this works you have a problem in the wiring. Make sure you have a ground to trans or it will not start...
REPLACEMENT FOR DISPLACEMENT
Old Mar 13, 2007 | 11:33 PM
Talon95's Avatar
Fakes the funk
when we tried to jump it my dad put the power cable on the power lug on the starter and it arc'ed and i also put a test light on it so i know its getting power, my dad mentioned about maybe its not getting grounded.anyway to check this? and if that is the problem whats another way of grounding it? sorry im a complete newb when it comes to wiring an such
Old Mar 14, 2007 | 03:21 AM
doeboy's Avatar
check the ground from the starter, to the chassis, and from the trans to the chassis. make sure they have clean conduits(sp) and go from there,
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
Old Mar 14, 2007 | 08:40 AM
Old Renegade's Avatar
Cool Runnings
checked the main relay?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Mar 14, 2007 | 08:57 AM
luvsracin87's Avatar
turbo hhhmmmm?
there should be a ground that goes from the chassie to the front ro the tranny case if im not mistakin. check that
Steve: (813) 810.4146 <~ call or text
Old Mar 14, 2007 | 09:50 AM
FC_V8's Avatar
yes, check if you have three grounds.. i pretty sure your suppose to have 3.
Old Mar 14, 2007 | 08:17 PM
Talon95's Avatar
Fakes the funk
so yeah, thanks for the help everybody,i checked all my grounds and they were fine so i was stumped.than my friend im'ed me tonight and brought something to my attention and yeah, i accidently didnt do the clutch bypass just right and after my friend showing me the right way to do it it fired right up. so a brand new starter and test light and hours of confusion/aggravation and it was a simple clutch switch gone bad anybody want to buy a used starter for a 91 integra? still works fine
Old Mar 15, 2007 | 04:32 PM
TSX24L's Avatar
damn i could have to you that from the start.
