obd0-obd1 injector question
Old Mar 7, 2007 | 05:54 AM
luvsracin87's Avatar
turbo hhhmmmm?
Default obd0-obd1 injector question
ok i just put my swap into another car and i used the wiring harness from the new car. my orginal haress had a resistor box( so i belive i have obd0 injectors) but the new does not(so i assume it had obd1 injectors), and i was wondering how my injectors were working with out a resistor box? if anyone could fill me in on this rep will be given.
if you need more info just ask plz
steve
Steve: (813) 810.4146 <~ call or text
Old Mar 7, 2007 | 05:58 AM
Walter's Avatar
Im as loyal as my options
all the resistor box does is controls the amount being sprayed
blah blah blah
Old Mar 7, 2007 | 06:07 AM
turbo hhhmmmm?
ok, i was under the impression that obd0 injectors would not work with out a resister box
Old Mar 7, 2007 | 06:38 AM
Walter's Avatar
they will work just not the way they are supposed to. and please be more specific on what swap you did. because if you are dealing with just ef's then the reason the other car has no injector resistor box isnt b/c it is obd01, in fact it isnt obd01 so more details please
blah blah blah
Old Mar 7, 2007 | 01:59 PM
turbo hhhmmmm?
the car was an ls swap from an ef hatch to a crx. both cars obd0
Old Mar 7, 2007 | 03:43 PM
60-1EK's Avatar
Engineer at the source
Huh?
To the original guy....ohm out your new injectors and post up what the results are.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 7, 2007 | 07:34 PM
turbo hhhmmmm?
Originally Posted by 60-1EK
Huh?
to do that all ineed is a multi-meter, and then just check the ohms running trough the injectors right?
Old Mar 7, 2007 | 08:02 PM
60-1EK's Avatar
Yep. Take the clips off and measure across the pins.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 8, 2007 | 04:28 PM
ricerboy05's Avatar
HITORI HOUSE MEMBER #3 Pit rescue s14
