gsr block with ls crank ????????????????
Old Mar 4, 2007 | 06:48 AM
BABILLARACING's Avatar
Default gsr block with ls crank ????????????????
Hi guys I am planning to sleeved a gsr block , I gonna be using a ls crank shaft , I know i need ls rods (I got a set of crower rods ) but the pistons is where I got the question . what piston I used the ones design fro ls or for gsr ? I gonna get them from wiseco . thanks in advance.......Omar
Old Mar 4, 2007 | 08:00 AM
civicized's Avatar
You need LS pistons. The rod is a different width than the gsr
Old Mar 4, 2007 | 08:27 AM
what are you saying that i need ls rods and pistons and I wont have any decck height isuess. right
Old Mar 4, 2007 | 12:24 PM
KJ's Avatar
KJ
bored at work
Get pistons for a gsr at whatever bore and compression you want. The piston saddle on forged vtec pistons is wide enough for ls rods. If you used a piston for a ls head the valve reliefs might not be wide enough.
Old Mar 4, 2007 | 01:19 PM
thanks man will do?
Old Mar 4, 2007 | 04:34 PM
FC_V8's Avatar
??...sure
Old Mar 5, 2007 | 06:47 PM
civicized's Avatar
If you have LS rods, the piston will be either LS or universal forged with no distinction but bore size. If a the piston manugacturer shows a gsr part and an ls part, it would be a difference for the rod width, most likely, as all aftermarket forged pistons have big valve pockets. Just check with the piston maker.
Old Mar 5, 2007 | 09:20 PM
rangcrx's Avatar
engine building &best
yup plus one..and you might have to do lil modifying to the cyl 1 and cyl 4 oilJet bolt just gind it down about 2mm and your good to go
i love AUTOZONE
Old Mar 5, 2007 | 09:23 PM
Kamikaze's Avatar
Li-Neezy™
I was wondering the same thing, except wasnt going boost, would type-r pistons fit on the LS rods and in the GSR block without much modifying?
Originally Posted by TampasOriginalSoarer
You're right I wrote the wrong word "psychologist" is what I meant..thanks
We all make DC's ..I mean mistakes !
Nikon D7000 | 18-55mm kit lens | 55-200mm VR | 50mm 1.8G |
GoPro Hero 3 Black Edition
Old Mar 6, 2007 | 05:36 AM
civicized's Avatar
The LS rods are too wide for the type r piston. The usual fix is machining off a bit of the rod small end to narrow it. I've never done this, but if I did, I would want to be exact, so as to keep the weight of the small ends the same on all four.
