what is interchangeable gsr
I want to put b20 pistons on my gsr rods to bring my block out to a 2.0 displacement. I want to know if the b20 pistons will fit the gsr rods with no modifications or very little. lmk, please help
b20 pistons will not fit the bore of a gsr block, so putting the pistons on the rods, which I suppose you could do, doesn't matter.
You can't bore the block large enough, as it would be over safe limits. You would have to sleeve it to get to 2.0
i'm going to sleeve my block with a bore size 84.5mm bore for a 2.0 displacement so yeah i already know that part, but i want to find out the question i asked, "Will a b20 piston fit a gsr rod with no fabrication to the rod or piston"
