keeps stalling but idles and drives fine until clutching, braking or turning...HELP
check the fuel pressure. Also check the tps wot and closed. When you changed the fuel filter did you check to make sure its not leaking? Sounds like a fuel restriction problem.
im going to take the fuel rail apart again and make sure nothing it blocking the injector micro filters again...
how do i go about checking the fuel pressure?
there are no visible leaks.... and i dont smell gas under the hood.
im not sure how to check the "tps wot and closed"?
thanks for the help...
_zac
_zac
build thread:
history:
1993 prelude s - SOLD
1996 integra gsr - SOLD
1995 jeep cherokee - SOLD
2001 cbr f4i - SOLD
1995 nissan hardbody - SOLD
2004 kawasaki zx6r - TOY
build thread:
history:
2001 cbr f4i - SOLD
Sounds like you have allot of rust floating around the gas tank. its probably clogging your fuel pump...
if rust is getting through you fuel filter youve got mad problems..
Id go try to find another gas tank..... and a new fuel pump... I had the same problem with my old hatch back. Thought it was the fuel pump dropped the tank to take allook and the gas tank was nasty as hell.
Cleaned it all out put new pump in and it ran perfect!! still does.........
Id try that.
Id try that.
welll... i ended up trying to take the easy way out.
i went to the auto parts store and got a thing of STP fuel system cleaner. i dumped it into my almost empty tank with a full fill up on high octane. now she is running perfect again. maybe bad gas???
thanks for the help everyone
_zac
_zac
build thread:
history:
2001 cbr f4i - SOLD
build thread:
history:
2001 cbr f4i - SOLD
thats the thing... i have never put anything under premium in any of my cars... ever. so i really had ruled that out in the beginning.... i filled up a full tank of 93 octane about 2 or 3 nights ago at rally gas station on the corner of gulfport blvd and pasadena ave in st pete. i dont know what happened.
_zac
_zac
build thread:
history:
2001 cbr f4i - SOLD
build thread:
history:
2001 cbr f4i - SOLD
Thanks for posting what you went through.
That helps us all get smarter.-Bob
Had a similar symptom? What fixed it for you?
