cv joints...
Old Mar 2, 2007 | 04:35 AM
MASTERSH/B91's Avatar
Default cv joints...
i have a 1991 honda civic hatchback and need to change them out, can anyone give me some simple instructions on ho to do that? thanks
Old Mar 2, 2007 | 09:07 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
im assuming you mean swap the whole axle... not just the joint.
1) pop the wheel hub nuts with a breaker bar/pipe extension while its on the ground.
2) jack it up
3) remove the upper control arm (two bolts) - should give you enough free room to wiggle the axle out
4) remove the shock so you can get the axle out
5) pop the axle out of the hub and trans
6) replace and reinstall...
unless the '91s are really different, this is just kinda generic civic/teg instruction, but its all straightforward.
Old Mar 2, 2007 | 03:06 PM
brax90si's Avatar
Also amke sure you have a some new trans. fluid ready. Because it will leak out of the trans when you pull the axle.
If you live in tampa. I can come do it for you. $30 dollars a axle. I am a ASE certified mech.
It is a easy thing to do, but if you are new at mech. work it can look difficult.
-Braxton
Old Mar 2, 2007 | 06:37 PM
UF Mech/Aero Eng
+1
good catch
