H22a into 95 Teg....
The swap itself is done.The harness from rywire came in today and is now hooked up....
I have a question about this swap,The FUEL lines....which honda acura will fit??I need a line thats about 2 1/2 feet (about)...I think an accord(91-95??) will fit.Im not to sure,but need to find out.
Also, the line for the clutch....its hydro,which lines can I use??the tranny had a rubber tube that was cut but the teg has the metal lines.....???...how can i solve this problem of getting it to hook up??
Ive done quite a bit of research on this and found alot of info...just need a little bit more.
Rep for help...
Thanks guys.
-Keith-
Rep for help...
Thanks guys.
-Keith-
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
C'mon faukers!!!!!!!!!
REP FOR HELP!!!!
Also,which cables will fit rather than the h22 cables,they seem to be a little bit shorter.....
REP FOR HELP!!!!
Honda-Tech.com: Hybrid: [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
Rep..
