BOOOOST build question.....
Old Feb 26, 2007 | 03:46 AM
94lsteg's Avatar
BOOST IS BETTER!
Default BOOOOST build question.....
Is there anything else I can do without ripping apart my bottom end that will make my LS more ready for boost?
This is what i have in plan so far....I plan on making around 260-280whp on a LS.
-ARP rod bolts, ARP head studs, and new OEM headgasket.
Old Feb 26, 2007 | 04:00 AM
hkshaitian's Avatar
To put on da arp rod bolt ur gonna have to rip apart the bottom end. Since ur gonna take out the piston u might as well get new piston rings.
Old Feb 26, 2007 | 04:12 AM
99B16Si's Avatar
y0 homie aint no gonna ripp part duh bottum end y0!
Old Feb 26, 2007 | 04:20 AM
94lsteg's Avatar
BOOST IS BETTER!
LOLOL..... ummm im pretty sure you can change the ROD bolts w/o ripping the bottom end apart right Dave?
Old Feb 26, 2007 | 04:59 AM
hkshaitian's Avatar
O u can? My bad for da wrong info.
Old Feb 26, 2007 | 05:12 AM
EGKID's Avatar
why dont you get a thicker head gasket, I was gonna say block guard but you have to get that pressed in, throw some cams in it
Ricky
Old Feb 26, 2007 | 06:29 AM
94lsteg's Avatar
BOOST IS BETTER!
i've heard OEM is where its at....??
Old Feb 26, 2007 | 09:59 AM
60-1EK's Avatar
Engineer at the source
Leave it at what you have listed. 280 is nothing on a stock setup.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 26, 2007 | 11:01 AM
94lsteg's Avatar
BOOST IS BETTER!
good shit
Old Feb 26, 2007 | 12:51 PM
Willis's Avatar
+1 dont rip it apart, leave it all stock, hell look at my setup just put 100k on my engine. It's never been pulled or anything before and im a 14.5lbs of boost with 10k on my setup and a/c making about 265whp which is plenty for right now.
