99 si problem
Old Feb 24, 2007 | 08:30 PM
Supraman757's Avatar
Mmmmmmk
Default 99 si problem
So i put some new rims on the car today and am having a new problem. Its making a really loud clicking noise and its buggin the hell out of me. It only does it when im not on the gas. When i brake and am accelerating I cant hear it. Its a clickin noise and it is constant is does it when i hit bumps too. If anybody would have an idea on what it could be please help me out. O yea and i put 17's on it . 99 Civic si. Thanx guys
Old Feb 25, 2007 | 12:07 AM
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
axles?.....maybe
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Feb 25, 2007 | 05:46 AM
TSX24L's Avatar
Was this doing this before put new wheels on it?
did it have center caps? maybe they are flexing causing a tick or a click noise?
You might have over torqued the axle nut or did you punch the axle nut it might be moving and causing the noise. I had from exsperience a axle nut on a new car were it wasn't torqued properly and the axle nut wasn't punched and it was just slightly flexing backwards causing a tick noise, manily over bumps not normal driving more so over bumps. It was a bitch to find this one until i exhausted alot of other possiable noises. Just a idea of things to check.
Old Feb 25, 2007 | 05:48 AM
civicized's Avatar
get the wheels off the ground and spin them up and let them coast with the power off them. You want to see if the new rims are contacting anything. Also, check the dust shields behind the rotors. Notorious for getting bent and rubbing things.
