shifter question
Old Feb 24, 2007 | 12:42 PM
VwDevon's Avatar
Default shifter question
i have a 1995 honda civic cx eg hatch and i wnat to buy and ebay short shifter. is it easy to put on and what do you have to do????. please help me out....
Old Feb 24, 2007 | 12:45 PM
mr.2fresh's Avatar
MID ENG, RWD, FTW!
well idk if its easy but itll sure stay on when you race, you jb welding mutha fucker aha
Old Feb 24, 2007 | 12:47 PM
VwDevon's Avatar
lmao doug you funny bastard....yeah i chopped my shifter and jb welded my shiftyer knob on there and it fell off now i want a ebay shifter
Old Feb 24, 2007 | 01:09 PM
VwDevon's Avatar
ttt....
Old Feb 24, 2007 | 01:47 PM
OMGVTEC's Avatar
Retired Moderαtor
A few pics from what comes in the package:
A couple of reference points as to where the stock shifter sits and where it positions itself in gears 1, 3, and 5:
Pretty much roughly 7 1/2" from the middle of the shifter to the ashtray.
Step 1:
The almighty ramps.
Step 2:
Remove shifter handle and rubber boot from floorboard.
Step 3:
Spray some WD-40 on exhaust hangers and remove the hanger.
Step 4:
Another hanger pic.
Step 5:
Move the exhaust pipe out of the way and unbolt the 2 12mm bolts that hold the rear extension to the body.
Step 6:
Remove the 12mm bolt and nut that hold the shifter to the change rod.
Notes: You can do this BEFORE Step 5 to have more support, but since I ALWAYS use a 1/2" Drive, I needed some space.
Step 7:
Drop the linkage out of the way.
Step 8:
Remove the linkage that bolts to the transmission. It's a 12mm bolt, no nut (self locking). Move it out of the way.
Step 9:
Remove the ENTIRE shifter linkage out of the confined space. Take it outside of the vehicle.
Step 10:
Place it outside.
Step 11:
Remove the 2 10mm lock nuts.
Notes: These have a flat to assist in remove the nut.
Step 12:
You'll need to grip the flat bolts with a pair of needle nose pliers to assist in removing the 10mm nuts.
Step 13:
Once the plate is off, the entire shifter and seal boot fall right out. Be gentle. Don't tear any of the boots.
Step 14:
With a pair of needle nose pliers, remove the sleeve from inside of the stock shifter. It's a sleeve with 4 grooves in it that takes 3/8" ID x 1/2" OD bushings/o-rings.
Step 15:
Remove all 4 o-rings from the sleeve.
Notes: Best way I found, was to pinch the o-ring from under, creating an "arch" above. Then, with your nail, roll them off.
Step 16:
Remove the dust seal and ball seat from the stock shifter.
You're done.
Now, onto the installation of the new B&M Short Throw Shifter.
Step 1:
Slide dust seal and ball seat onto the new shifter. Might take a little oomph here and there.
Step 2:
With the supplied White Lithium grease, apply some onto the "ball".
Step 3:
and
Insert new B&M Shifter back onto the change extension.
Notes: If you notice, one side of the plate is squared off and the other side is rounded off. THE SQUARE SIDE POINTS FORWARD TOWARD THE TRANSMISSION!
Tighten the 2 10mm nuts. You'll need to use the needle nose pliers once again, it's a bit tricky, but MAKE SURE THE NUTS ARE FULLY SEATED!
Step 4:
Grease the OEM sleeve with the supplied grease. Grease this piece liberally.
Step 5:
Insert the new 4 o-rings that came in the package. Grease some more all over the sleeve and o-rings.
Step 6:
Grease the inside of the shifter, where the sleeve sits.
Step 7:
Enter the sleeve. It might take a bit of a push and a couple light taps of a mallet, it'll go through. Make sure you have the same clearance of the exposed sleeve on both sides.
Step 8:
Go under your car again and place the entire shifter linkage back onto the location where it sits.
Also, grease both of the ends of the sleeve. 2 more o-rings (supplied on the package) will sit here.
Step 9:
Now, get the 2 9/16" ID x 3/4" OD o-rings and sit them on the ends of the sleeve. Makre sure you grease nicely.
Step 10:
Bolt up the shifter to the change rod and make sure the o-rings are properly seated. Bolt on snug.
Step 11:
Bolt the 2 12mm bolts back onto the rear extension mount. Bolt snug.
Step 12:
Hook your hangers back on.
You're DONE!
Install time: +/- 1 hour. Depending on how thorough you are that everything is installed properly.
Here are some after pics of the new B&M Short Throw Shifter:
DEFINITELY shortened gears 1, 3, and 5 by 1 1/14" to 1 1/2".
As you can see, it also sits forward. This shifter DOES NOT have a bend on it. Straight shaft.
Notes: If you are tall and sit really back, this shifter might not be for you.
or
If you sit like a homo-thug all back, don't get this shifter, it's not for you.
I sit decently up front. 1, 3, and 5th gears are in arm's reach. My arm is almost fully extended to engage the gear.
I'm 5'10" by the way.
Old Feb 24, 2007 | 02:17 PM
VwDevon's Avatar
thanks man im getting an ebay short shifter, do i have to the same thing as the b&m shifter?
Old Feb 24, 2007 | 02:50 PM
OMGVTEC's Avatar
Retired Moderαtor
same steps
Old Feb 24, 2007 | 05:24 PM
freakasis's Avatar
dont waste your putting a short shifter on a stock cx. if your gonne invest $30 in a shifter, just spend twice that and get an ex tranny...you will actually be faster then.
VwDevon's Avatar
alright thanks for ur time
Old Feb 25, 2007 | 03:12 AM
pepperinyoureye's Avatar
mine snapped in half after like a month of having it
2000 Silverstone AP1
1998 Turbo SC2
