Help!!! This idle is driving me nuts!
Old Feb 18, 2007 | 05:30 PM
DrEwDaKiSs's Avatar
[pending...]
Default Help!!! This idle is driving me nuts!
Ok. So after my car warms up and I drive it for a bit; when I come to a stop my rpms bounce from about 1000 to 1500 rpms. Its terrible! I got a tip that it was my "idle-air control valve" so I got one of those from my friend (a used one) and it kept doing the same thing. He said he was pretty sure that the idle-air control valve he gave me was good. So I have no idea. Also when I put on the supposedly "good" valve I also cleaned up my "f.i.t. valve" (fast-idle-throttle i think). And then I made sure that the plastic circular piece inside of the f.i.t. valve was screwed down tight. But still my rpms bounce... Sigh... Should I jus pay $160 for a brand new idle-air valve or could it be something else? Help... Please... I have a head-ache...
Old Feb 19, 2007 | 07:57 AM
DrEwDaKiSs's Avatar
[pending...]
Old Feb 19, 2007 | 08:02 AM
Old Renegade's Avatar
Cool Runnings
could be a vacuum leak somewhere. my car has been like that for a while but not so high. did what you did and i have not resolved it. get used to it i guess.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Feb 19, 2007 | 08:10 AM
angelR82's Avatar
slow s10 extreme
the motor is blown sell me your car now for 500.00 and save thousads lol chk your intake for any leaks could also be one of your air hoses not connected i had that problem on my corolla they mechanic said it was the intake manifold gasket ??
Old Feb 19, 2007 | 08:22 AM
DrEwDaKiSs's Avatar
[pending...]
gracias gracias. and angel... ha ha ha funny.
Old Feb 19, 2007 | 09:00 AM
Obviousreasons's Avatar
Welcome to Candy Mountain
Check the adjustment screw on the TB, While the car is running turn it either direction and that will probably help it out. There is another adjustment screw that you can adjust if that one doesnt help, but its a MoFo to get to.
Good luck.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Feb 19, 2007 | 09:03 AM
DrEwDaKiSs's Avatar
[pending...]
Good luck.
yea i tried the one on top and it did nothing. where is the other one? and thanks
Old Feb 19, 2007 | 09:07 AM
It is on the bottom side of the TB. Its actually a Nut. I believe its an 8mm. And there is an allen head in the middle that adjusts it. The nut just keeps it locked into place. Its a Bitch to adjust. Good Luck.
Old Feb 19, 2007 | 03:13 PM
little_j04's Avatar
speedracer
OK try this if you can get your hands on a propane torch. Take the torch but DONT light it just let the propane flow out and while the car is on manuever it between the intake manifold and the head and run the unlite torch along the gasket. If there is a gasket leak then it will idle higher if not then nothing should happen. I have the same problem you have. A leak between the head and the manifold could be the problem.
>ENDless SPEED<
Old Feb 19, 2007 | 03:27 PM
DrEwDaKiSs's Avatar
[pending...]
thanks for all the insight guys. ima take another look at it and see what i can do...
