turbo and fans
Sometimes a stock fan can be used as a low dollar solution, and to make it a pusher, you reverse the polarity of the wires, and make sure the mounts are not grounded..............unless you NEED a thin fan.....then you HAVE to buy an el expenso fan.-Bob
I use aluminum sheet metal to make a shroud/duct, and I would duct it straight to the car front for maximum air flowing through the radiator. For an intercooler, I would duct it tightly to the car front, so that no air escapes, and maybe run the duct down lower with a scoop/spoiler to grab more air than what comes through the stock grill opening.-Bob
^ thats pretty much what i had on my LS-T integra... i cut the stock rad fan shroud just enough so it would fit infront of the radiator(used as pusher) then i just reversed the polarity and it worked fine... here the ghetto part(or even more ghetto?), it was shuch a tight, perfect fit between the rad support and the rad i didnt even need to have fan mounts, it was perfect.
Sorry for the late reply. Here is a picture of my fan shroud
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
