what is this noise!?!?!?!?!?!?!?!
Old Feb 8, 2007 | 01:29 PM
njg86's Avatar
buy my artificial cement
Default what is this noise!?!?!?!?!?!?!?!
alright,1st,2nd,sometimes 3rd...just at low rpms when you let the clutch out it will start making this kinda vibrating noise,push clutch in its gone,go into higher rpms it goes away,,anyoe have any idea what it could be,tranny shifts and does everything fine,its just a vibrating noise it sounds like,but could get loud. is it possible there is to much tranny fluid or to little? thinkwe put a quart and half in it...
Old Feb 8, 2007 | 02:39 PM
SmokinS13SR20's Avatar
That ginger...
Does your clutch slip at all?
Sounds like a throwout bearing though...
nolexforever's Avatar
bad throw-out bearing? i know mine gives off a slight vibration/rattle noise from the clutch pedal.
Old Feb 8, 2007 | 03:11 PM
wearyfurball's Avatar
its the noise in the tranny or the shirfter? Cause if its the shifter it maybe your mounts
Old Feb 8, 2007 | 03:18 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
Could be your tranny main bearing. That was almost the exact same stuff mine was doing. Contact Neal Sutton. AKA: Cxcivic
He can fis it for you.
G/L
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Feb 8, 2007 | 03:57 PM
civicized's Avatar
throwout bearing makes noise when clutch is depressed, input shaft bearing makes noise while driving and in neutral but not when the clutch is depressed. Other bearings in the trans make noise only when driving and clutch out.
Old Feb 8, 2007 | 04:13 PM
njg86's Avatar
noise is coming more so from tranny,we had the car on jackstand and put it in first,and i was under there trying to see if i can find antyhing it woud be,but nothing in view. bearing is possible,that was mentioned to me before i posted the question on here,is that a pain in the ass to fix or basically needing a new tranny?
Old Feb 8, 2007 | 04:50 PM
kaluwa's Avatar
My 2000 si does the same thing but mostly in 2nd and 3rd gear. It does it when your in gear and slow down and the rpms drop under 2k.. It's like a humming noise, and it sounds like it's coming from the tranny. Then when you push in the clutch it stops. I have to get mine checked out too, anyone know what it can be?
Originally Posted by steezyteg
ok guy your the idiot.
Old Feb 8, 2007 | 06:13 PM
Like i said, I would PM Cxcivic and see what he says. He isn't gonna charge you for asking his opinion.
