Help With Iacv
Old Feb 5, 2007 | 08:22 PM
Grizzly0205's Avatar
**BoTtLeS aRe 4 BaBiEs**
Default Help With Iacv
ok.... I Noticed That My Idle Was Going Up And Down From About 1000 To 1500 After It Warmed Up....so I Took Off The Iacv And Noticed The Screen Was Completely Black So I Got Everything Out Of There And Cleaned It Real Good I Let It Air Dry About 30 Minutes... I Got It Put Back In And I Start Up The Car And Now The Car Idles At About 500.. I Have A 92 Integra With A B16... Any Help With Be Appreciated..
Old Feb 5, 2007 | 08:42 PM
mtber's Avatar
You may have killed the iacv valve or made the clog worse...
Does it sound like the valve is working ?
Old Feb 6, 2007 | 02:35 AM
hondachris1994's Avatar
hatchback1994
Thats how I cleaned mine, do u have a CEL on? Also did u plug the IACV connector back in, and did u hook both lines back up?
Old Feb 6, 2007 | 03:09 AM
I believe its working but when i took it off it only had one bolt in it you think that will cause something like that???
Old Feb 10, 2007 | 12:36 PM
0gravity's Avatar
vacum leak?
Old Feb 10, 2007 | 08:52 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
uh, idle adjustment screw?
have you tried raising the idle per honda spec?
Old Feb 11, 2007 | 04:26 AM
TSX24L's Avatar
if you used brake cleaner or carb cleaner you can damage the seal or deteriate the o-ring.
Old Feb 11, 2007 | 10:24 PM
Jdm-civic88's Avatar
i'm having the same problem
Old Feb 15, 2007 | 06:13 AM
94civicb16's Avatar
me too
Old Feb 16, 2007 | 02:18 PM
b18civ's Avatar
vacuum leak or timing, if you wanna check the iacv put some voltage to the plunger to see if it opens, or is it closes? Anyways
