dsm injector help
Old Feb 3, 2007 | 07:10 AM
el b18's Avatar
$$ = boost :( = NA
Default dsm injector help
just for verification.
1. dsm bluetop 450cc injectors are compatible with OBDI honda clips?
2. i need to dremel the bottom injector seal on the manifold or use a new injector seal kit..? what seal for what vehicle?
3. and i have the resistor box..anything else?
thanks in advance
anthony
ive searched for days, aparently there are many methods, just lookin for advice
Old Feb 3, 2007 | 07:25 AM
dablkac's Avatar
lol yeh them TR cocksuckers are some cocksuckers ey?.. good luck.
Old Feb 3, 2007 | 07:51 AM
oldschool98's Avatar
Painter Extrodionaire
DSM Injector Install
Just google or yahoo,keyword:dsm injector install
Old Feb 3, 2007 | 07:44 PM
el b18's Avatar
$$ = boost :( = NA
thanks.. looking for anyone with experience on this topic
Old Feb 3, 2007 | 10:43 PM
mtber's Avatar
thanks in advance
anthony
1. Yes
2. You can use the factory seals. Sometimes the bottom oring needs to be honed out slightly.
3. You need to properly wire in a resistor box to run dsm low impedance injectors.
Old Feb 5, 2007 | 10:40 AM
seventhgear's Avatar
hanglike sleeve of wizard
if installing in a 90 crx would you still need the resistor?? or are they low impedence as well?
image removed from your sig...see forum rules
Old Feb 5, 2007 | 04:58 PM
FC_V8's Avatar
the dsm 450's are peak&hold and means it needs resistor box and the Saturaded injectors doesent need resistor box. i think thats right..lol..
anyways.. i've installed 450's with resistor box, in my cusions ride and its pretty simple.. go threw the steps 1 by 1. Look it up on Honda-tech.
Old Feb 5, 2007 | 05:40 PM
mtber's Avatar
A 90 crx should have a resistor box installed already.
Old Feb 6, 2007 | 06:51 AM
itsslow's Avatar
I-VTEC, do you?
^ correct.. if not, any OBD0 resistor box will directly plug into OBD1 wiring harness.. its cake
Old Feb 6, 2007 | 06:54 AM
Steve C.'s Avatar
hoollaa
Goodluck man!
