Help with D16Y7 into 1992 Civic
Old Jan 29, 2007 | 07:32 PM
aznkhmerracernza's Avatar
Default Help with D16Y7 into 1992 Civic
My Friend Swapped My old D16Y7 Into His 1992 Four Civic DX. I'm having trouble starting it up. At first we Thought the Dizzy would work but it end up not working. So we used A OBD2 Dizzy re-wired to work. We can't seem to get it to start running. We are missing a Orange wire to Dark Blue wire connection which is known as the CKPP Function. Has anybody had this problem?
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Jan 30, 2007 | 12:06 PM
crix's Avatar
:mugen member:
you put the 92 harness on the y7 motor correct? then use the 92 distibutor it should start......if it doesnt fit find an OBD-1 DIST.. That does....
Old Jan 30, 2007 | 07:49 PM
Well here's the thing. He had a D15B7 motor in it before and I swapped it out with a D16Y7. His old dizzy is totally different in mounting.
Old Feb 1, 2007 | 02:50 PM
cheeseburger407's Avatar
he need to buy ob1 dizzy and it should start. did he use hie ob1 injectors? if not he need to
Old Feb 4, 2007 | 08:03 AM
SilvCivOn17s's Avatar
cause the whistle goes...
obd2 injectors wouldnt plug into a obd1 harness anyway
R.I.P. Brian Nichols 02/07/1989-11/23/2008
Old Feb 4, 2007 | 09:49 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
CKP = crankshaft position sensor
the ECU will not run a motor without this sensor installed and fucntioning (and OBD2 ECU wont, im not sure about OBD1)
Old Feb 4, 2007 | 08:06 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
all non vtec sohc heads have the same dizzy bolt pattern....u should be able to bolt up b7 dizzy no prob at all....u used obd1 injectors and harness right?
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Feb 5, 2007 | 06:31 PM
I used OBD1 Injectors and Harness. Still not getting spark.
Old Feb 5, 2007 | 06:35 PM
HondaHouse's Avatar
check ur grounds to motor and trans....AND ALSO HARNESS GROUND AT T STAT HOUSING...COMMON GR OUND MISSED..CHECK UR IGNITION FUSE IN FUSE BOX AND ECU ALSO
