idle 1990 civic hatch
Old Jan 28, 2007 | 07:01 PM
dakota_civic's Avatar
Arrow idle 1990 civic hatch
at idle my car revs up and down....it drives fine and the ecu isnt throwing a code or anything so what could it be???? o2 sensor???? or the sensor in the fuel rail is dirty????
Old Jan 28, 2007 | 07:03 PM
Thatguysstuff's Avatar
Hey its that guy!!
Should be your Idle air control Valve is dirty or clogged up. Its the sensor on the back of your intake, Kinda big!! Should have 2 or 3 bolts on it.
Old Jan 28, 2007 | 07:10 PM
superhondaboy's Avatar
bleed cooling system,bleeder valve should be on thermostat housing,sometimes it works.good luck!
Old Jan 28, 2007 | 07:16 PM
you have to bleed it while the car is at idle and let all the bubbles and air bleed out until coolant is shooting out solid stream.
Old Jan 28, 2007 | 07:21 PM
LOLWAT's Avatar
Registered-Honda-User
is it a d series motor?
Oh Hai!
Old Jan 28, 2007 | 07:25 PM
stockCRXsi's Avatar
if it is a single cam this is all the info you will need for a 1990 civic
good luck
http://www.ef-honda.com/ben/Badidle.php
Old Jan 28, 2007 | 07:29 PM
LOLWAT's Avatar
well i was going to say if its a single cam, there is a censor near the intake manifold and you can just un plug it and the idle problem stops. I did it on my last crx.
Oh Hai!
Old Jan 28, 2007 | 08:13 PM
what sensor is this,sensor must have been bad to stop problem when unplugged!
Old Jan 29, 2007 | 12:52 PM
thanx guys......i unplugged the iacv and that was what the problem was.....i appreciate all your help
