stock fuel pressure on 99 ls teg?
Old Jan 27, 2007 | 11:24 AM
TIM TIM TIM's Avatar
could be worse
Default stock fuel pressure on 99 ls teg?
title says it
aim:because tim said
Old Jan 27, 2007 | 01:50 PM
hondachris1994's Avatar
hatchback1994
I think its around 30 psi
Old Jan 27, 2007 | 02:17 PM
GsEclipse02's Avatar
42psi
Old Jan 27, 2007 | 03:48 PM
hatchback1994
With regulator vacuum hose attached 31-36 psi, with the regulator hose disconnected 40-47 psi and these are both at idle
Old Jan 27, 2007 | 06:46 PM
could be worse
what regular vacume hose? my car is very stock, someone before me decided to put on an aem fpr and fuel rail. i feel its retarted and want to make sure the fuel pressure is stock, i dont see a point in wasting gas on a near stock car.. soo stock as it would come would be 31-36?
Old Jan 27, 2007 | 07:28 PM
hatchback1994
Originally Posted by TIM TIM TIM
what regular vacume hose? my car is very stock, someone before me decided to put on an aem fpr and regulator. i feel its retarted and want to make sure the fuel pressure is stock, i dont see a point in wasting gas on a near stock car.. soo stock as it would come would be 31-36?
yes those are stock psi, and stock or aftermarket, it has a vacuum hose, it should b goin from the intake manifold to the regulator
Old Jan 27, 2007 | 09:01 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
didnt you already make a post about this a while ago in which i gave you a detailed answer, or is it just deja vous???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jan 27, 2007 | 09:53 PM
mtber's Avatar
Your static fuel pressure on a b18b should be 40-47 psi according to the helms manual. This is with the vacuum hose disconnected from the regulator and capped.
Old Jan 28, 2007 | 10:12 AM
could be worse
i had asked and never got a responce, maybe you did respond and i didnt look again since then..
