built gsr break in question
Old Jan 24, 2007 | 03:52 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
Originally Posted by sprjit22
Im kind of leaning towards not boosting it untill it is broke in. Wich means getting it tuned two times. Iv got soooo much money tied up in this damn thing I double check everything just to make sure its right.
not that Jason and John don't know 100% what they are talking about, and do this on a daily basis, but im kinda with you on this one...
if you are really worried about hurting something by having the boost on during breakup, which is a reasonable concern, why not just run it stock till you break it in? like John said, throw on some stock injectors, run an OE ECU, and drive it like a stock GSR for 1500 miles...
that way, you are 100% positive that its solid when you throw on the turbo and boost its brains out
but like John said, everyone's got an opinion. i would just err on the side of cautious in your situation...
g/l bro!
Old Jan 24, 2007 | 03:55 AM
Alpha's Avatar
I will post when I get home later but the motor is usually broken in within the first half hour of running it. My personal motor had 190 compression across after twenty five minutes. Startup. Street tune. Dyno tune
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jan 24, 2007 | 04:35 AM
NSXtacy's Avatar
Go Fast Crack Pipe
It does not matter N/A or Boost. Mtber is correct. The startup tune is critical. You dont want to wash a cylinder out on your new motor. Call a professional tuner and buy a wideband like the UEGO. This is more important than an RPM gauge!
"It's OK to Smoke V-8's" - Surgeon General
www.2NRWerks.com - NSX, S2000 & RSX specialist. AEM, Hondata Kpro & Crome tuning provider. Custom built F, K & B series motors. Custom "Safe" Nitrous Kits and NOS Refills (While-U-Wait). Suspension/Brake Specialists & Alignments for lowered cars. On the quest for 700whp S2000 roaming the streets early Spring.
To Schedule An Appointment Call: (813) 876-VTEC
<< Reputations are so overrated! Don't hate on me 'cause I build fast cars.
Old Jan 24, 2007 | 05:27 AM
T4eg's Avatar
Ive never broke in a motor, They go straight from lift to dyno. Last motor i built went straight from lift to dyno 16pulls later was 670whp. Just MAKE sure that as stated above that car is tuned on initial startup.
chris
Old Jan 24, 2007 | 06:58 AM
Alpha's Avatar
I will break down what I did with my person motor and what I do with other people's personal motors (friends, customers, etc). Turn off the injectors/coil. Turn the motor over a couple times. Start the motor and start to dial in the A:F. Have someone else check for leaks. Once the A:F is dialed in and we establish there are no leaks I set the idle to 1500RPM for a couple minutes. Then to 2000RPM for a couple minutes. Finally to 2500RPM. This takes about twenty five minutes. While at 2500RPM I will free rev. After twenty five minutes I change the oil and oil filter. Take the car out for partial throttle street tuning. Change the oil and oil filter again. Take the car out for full throttle street tuning. Change the oil and oil filter again. Finally take it to the dyno and make some power The oil and filter are changed quite a bit but I use and recommend Castrol GTX which shouldnt be a big deal considering you just spent a bit of change on the build and setup
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jan 24, 2007 | 07:22 AM
KJ's Avatar
KJ
bored at work
I like to start my turbo motors up with everything installed except a stock ecu and injectors this way you can start it up and confirm no leaks or anything is mechanically wrong before you waste a tuners time coming out to your car and not being able to tune it.
I made this mistake before and called John out to tune a car and when we started it up the turbo feed line had a leak from where the fitting was crimped which basically made the night a waste of time.
Old Jan 24, 2007 | 11:34 AM
  #17 (permalink)
NSXtacy's Avatar
Go Fast Crack Pipe
Thumbs up
Ditto
Old Jan 24, 2007 | 01:32 PM
  #18 (permalink)
T4eg's Avatar
I will break down what I did with my personal motor . Turn off the injectors/coil. Start the motor and start to dial in the A:F.
alpha how does it start with no injectors/coil? just wondering and i ran out of vtec fluid
Old Jan 24, 2007 | 02:32 PM
  #19 (permalink)
Alpha's Avatar
Stfu
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Jan 24, 2007 | 03:51 PM
  #20 (permalink)
sprjit22's Avatar
Rick James bitch
thanks for al the input & advice. REP given
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
