blue smoke when sitting over a day.....
Old Jan 14, 2007 | 10:37 AM
cubanprince1's Avatar
shift.............vroooom
Default blue smoke when sitting over a day.....
I have a 00 civic si and its been boosted for about 800 - 1000 miles...the engine has 56k on it.....ok, so i didnt drive the car yesterday and today when i turned it on it was smoking blue everywhere....alot of smoke....the thing is on dp so i looked under there and it was just puffing out blue smoke.....i guess im burning oil but after i started driving it went away....when i get on it hard ill see a little smoke come inside the car cuz the dp is right under the shift knob.......i have an oil leak which is right on top of the dp so i thought it was oil dripping on the dp when hot but when i got under there to look today i noticed it was puffing blue smoke.....yes i know i know, rings or valve seals but why will it go away? the turbo kit was brand new btw........
http://inductionperformance.com/
Induction Performance - 727.505.1423
AEM EMS Tuning, Builds, Assembly, Custom Kits, Installs and more.....
Old Jan 14, 2007 | 10:41 AM
zedron's Avatar
What kind of turbo kit is it?
Old Jan 14, 2007 | 10:55 AM
sc61, lht components, aem etc...why does it matter though?
Old Jan 14, 2007 | 10:59 AM
civicized's Avatar
valve seals. goes away because the oil leaks down past the seals when the car sits, gathering in the cylinder. When running, some oil is passing in real-time, but not enough to cause a blue cloud the way it would after sitting a while.
Old Jan 14, 2007 | 11:22 AM
hmmm.....that makes sense.....so if i let it sit for a while and pull a plug i should see oil accumulated on one or more of the pistons? if so, would it hurt to keep driving it like this? How hard of a fix is it and how expensive?
Old Jan 14, 2007 | 12:28 PM
civicized's Avatar
valve seals can be replaced without pulling the head, but it is a bit of a pain. You have to take off valve springs, retainers, etc, and also keep the valves from dropping into the cyl via air pressure in the cyl. Also a big risk of losing a keeper down in the head somewhere.
Leaking seals don't harm anything, thought he smoke is annoying. I'd say live with it until it's time to rebuild.
Old Jan 14, 2007 | 12:59 PM
if it was leaking seals wouldnt it loose oil? I check the oil almost every other day and i dont really see it loosing oil.....
Old Jan 14, 2007 | 01:23 PM
1BADP71's Avatar
E & I Certified
you wont notice such little oil gettin past if its this recent . hard to judge such a small amount on an archaic metal rod dipped into an unlevel oil each time you check it .
Old Jan 14, 2007 | 01:24 PM
i have an oil leak as well...
Old Jan 14, 2007 | 01:26 PM
1BADP71's Avatar
E & I Certified
so fix that , pull the head and put all new seals in . wont take more than 1/2 day.. you should machine the head while your at it though for added protection and testing measures.
