ITR Swaybar on ebay, confirm please
ok so how much does a itr sway usually run then
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
TR H2B crew #2
When I do an a-x setup, I go with heavy sway bars first,
and see how the car handles. Does the tail hang out first, or does the front plow? I then compensate to make it driveable, and "tossable" at speeds.
I have had good luck with stock springs, heavy shocks and heavy sway bars. Heavy bars on both ends work differently than one bar on one end only. Heavy springs are not a substitute for sway bars, and sometimes CAUSE a loss of handling. I also do things with alignments, ride
heighth and roll centers to make the car work better.-Bob
ok so i can get the ITR 23mm rear sway, and the stock sway on a SI is 22mm up front, is a bigger front sway a good thing to think about? Im trying to set my Hatch up for some autox
Also i read that High Springrate springs up front + swaybar up front= bad, when you use high rate springs you would just take the bar off.... does anybody autox a hatch or know anyone that i could talk too so i can learn a thing or two about suspension setups?
thx
thx
