Questions about LSV build
Right now I have a B18a1 out of a 93 ls. What I want to knoow is I'm getting a b16 head to do a LSV build. The heads from a 00 SI, my questions are what is everything I'm gonna to need to make this work. I was told I'm gonna need GSR head bolts cause the b16's are to short and the ls's are to long. Also am I going to need to get a OBD conversion for the dizzy? Would it be easier to just rewire the car to to the new OBD (not sure what 1 I have atm and what 1 the 00 b16 head takes) and get the right ecu for it, or just get a vtec controller and use a conversion harness. Money is sorta a issue but not really. Basically I Need to know every single part I'm gonna to need so I can start getting them.
also if u want it to be SAFE...u need to take the bottom end apart and put some arp rod bolts in there...and depending on what way u want to go..all motor or n/a maybe consider changing the pistons to some high comp p30s (jdm b16 pistons) arp head studs would also be a good thing to have....i think u should honestly rebuild the whole bottom end to be safe..but u can take ur chance on that...or if u want i have a ready built ls bottom end..thats vtec readya(i have one pm me)....cuz ur also going to need a vtec water pump and oil pump...i mean u can use the ls...but thats not very smart since its not intended for the high revving vtec motor...try not to cut corners and do A LOT of searching before you get this done..there are millions of sites out there with ls/vtecs and b20vtecs to learn from...
I dont plan on going cheap with this but I also dont wanna get stuff that I dont absolutly have to have. Way I'm looking at it is the more it cost the longer and takes. I want to get this done but at the same time I want it done right. I plan on keeping it N/A. I know I need arp head studs, itr gsr oil pump, itr gsr water pump, LS/vtec oil kit like the one linked below. A chipped ecu to remove the knock sensor. Would it be easier to get a obd1 dizzy or a convert the dizzy plug for obd2 to match the dizzy I'm getting with the head? I belive the car is running OBD1 atm has a pr4 ecu. I'm gonna get a vtec controller also. what else do I need to get?
eBay Motors: LS VTEC Oil Line Conversion kit COMPLETE W Head Gasket (item 280067783763 end time Jan-13-07 13:40:31 PST)
please read the sticky at the top of the tech forum. there is more LS/VTEC info on there than we could fit in one thread.
g/l with your build.
*EDIT*
AND NO VTEC CONTROLLER! please do it the right way, and the easy way and use a VTEC ECU
*EDIT*
just buy my ls bottom end...its built correctly..and would be cheaper then u buildin it urself..it only has 6000miles on it...ls rods..arp rod bolts..p30 pistons(81.25mm) oem rings oem bearings ls crank that was polished before hand..vtec water pump and oil pump it yields a compression of 11.56 with a stock b16 head and oem head gasket sellin for 600obo..lmk..this will be a complete bottom end and u can sell ur ls bottom end for 300 or so? so u would be makin out pretty well..pm me
Golden Eagle LS VTEC kit FTW!!!!
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
..just my 2 cents
